Will 20" (silverado ss) rims really hurt my performance THAT much?
#21
Originally Posted by BADMOFO
I would sell the tires (way too tall for a 2wd, in my opinion) and try to score some 275/45/20's or maybe even something a tad smaller. I run 285/50/20's which are actually shorter than stock SS wheels/tires and my truck runs 3-4 tenths slower than it does with the Cadillac Escalade wheels and 275/55/17's. Braking is also VERY noticeable.
your biggest factor is the tire diameter. I vote for loosing the 275/55 in place of the 275/45. their is a picture of my truck in the sig with the 275/55 and a 2" rear drop. the 275/55 definitely fill the fenders but a little overkill for my taste. It kinda has that hotwheels look
the 265/50/20 is another option that I think is the exact height of the factory tire. either way keep the 20's, they look much better. I had no idea the SS wheels were that heavy. I would hope my forged centerlines are lighter than that
#23
So basically what you're getting at then is you think the overall tire height is going to kill me more than just the added weight of the wheel? I've read so much about sprung and unsprung weight in the last 10 hours it's not even right I think I'll try them as is, unless someone wants to buy these new tires from me with less then 100 miles on them. Then I can get some proxies or something a little more performance oriented than the goodyear LS's. By the way smooth sierra, I like your truck and the way it looks in the sig
#24
with those ss wheels you will feel a difference especially with that big tire cause it is going to kill your gearing. like they said, you need to go to a 275/45 or a 265/50-20 to get closer to the factory tire height. if you got a good deal then you may consider selling them and buying a set of wheels and tires that are lighter. my stock steelies and tires weighed in at 60lbs a piece. my 20's with the 265/50's weigh in at a wopping 68lbs each. i could tell a little difference but not enough to make a difference considering the cornering gains. but i think the theory of unsprung weight (ie. heavier wheels) is for every 100lbs of unsprung weight is worth a tenth in the 1/4. so you can gauge the difference in performance by the difference in wheel weight. i would sell them though and do some research on wheels and find some lighter weight 20's like the centerline billets or something. they are inexpensive, pretty decent styling, and light. just my .02's.
#25
you will not notice daylight and dark differences in performance. Like it was said maybe one tenth in the quarter.
#26
Compared to a light weight wheel like a Centerline you will lose up to about 3 10ths in the 1/4 I bet.
The height hurts but I htink the weight hurts more. Now if your original rims/tires weigh 70lbs then the diff. in weight isn't so bad. About a 10th maybe.
#27
Time to drag out the bathroom scale. I've got heavy michelin LTX M/S tires on facotry 16" chrome steel wheels. I only think the SS rims/tires are about 10 pounds heavier a piece. I need to put them on the scale to be certain though. I might be able to get at my truck (it's in the back garage sleeping for winter) and take one of the stock rims off with the michelins to compare weight.
#28
Get some smaller tires for the wheels. 275/55/20 is rediculous anyway. My stock steel wheels weighed around 59-60 on my bathroom scale and my 20" centerlines on 245/40/20 hankooks weighed 51 lbs. I'll take 9 lbs lighter per wheel anyday of the week Also with the shorter tire and lighter weight my truck feels much faster on 20's than on stockers plus I get better traction with the high performance tires, not to mention the good looks
#29
Ok I looked back at my posts to find when I was trying to figure the weight differnce between the stock 16's and the SS 20's with tires. The SS 20's weigh 26lbs more with tires than the stock 16's with tires. So a total weight difference of 104lbs give or take with different tires. I just got sone taking my SS 20's off about 2 hours ago. I just got the LS1 in and want to feel all of it. I can only tell slight differnce but I only have like 70 miles on my new tune so there is probabaly some learning left.
#30
There really are three things about swapping to 20's that are detrimental to performance.
1.) Tire outside diameter: If you end up with a larger outside diameter its equivalent to changing rear end gears. If you go from 30" od tires to 32" od tires, its equivalent to going from 3.73's to 3.50's (which I know isn't a factory gear, but thats not the point).
2.) Unsprung weight: This is the weight that your bathroom scale can measure. If the wheel and tire is 15 lbs heavier, then you've got 15 lbs more unsprung weight. It will have an affect on handling, but not much affect on acceleration or braking.
3.) Rotational weight: This is the other killer for acceleration and braking. Basically the larger wheels move the weight further outside, making the rotational inertia bigger. Alot of the weight in a wheel is not in the center section, its in the rim, and as the wheel diameter gets bigger, the rim gets both longer (more circumference) and moves further from the center of rotation (I know, duh). These both act to make the wheel "feel" heavier (its a better flywheel, so to speak). This is the effect that you can't compensate for with lower profile tires, the weight is further out and there's nothing you can do.
For all out acceleration performance, I wouldn't go past 17's. 15's or 16's would be "better" in a straight line type contest. You'll notice most of the "serious" drag cars run small (15") wheels for that reason (and to make the most of wrinkle wall slicks.)
I don't know if that helps any, but figured I'd throw my $0.02 in the pot.
'Dreamin'
'Dreamin'
