will a 6.0 swap get me there?
#21
Registered User
yeah a n/a 6.0 i think would be the safe way to go i figure with a good set of afr heads holley modular intake and cam should be a good dependable setup and get me hopefully where i want to be maybe throw 150shot of juice to help at the track
#23
Registered User
sooo you n/a guys with 6.0 think with the parts i have talked about will get me atleast 13.50 at the track with 4.56 gears and 3500 to 3800 stall on motor
#24
I would call and match up the cam stall and gears to see witch is the route you wanna take. It makes all the difference in the world to match these up. You can get a custome grind. There are guys out there that will tell you what works with what the best it's there job. The higher the stall the more of a pita it is to drive a slow speeds. Lots of factors in picking out a stall cam and gears you want bottom out the hole grunt, a strong mid range, top end. I wanted the best all around for my DD. Is why I went with my setup. It works great for my needs.
#25
Registered User
these trucks are a whole new ball game for me for sure but around home here there is nobody but desiel guys that mess with trucks and i really want to turn some heads ha ha so jco3ss what is your set up got any times
#26
I haven't got any times yet. I will soon as the track opens up. I'm in Homestead fla. We have only 1/8 here. I'm shooting for 8.40 ish in the 1/8. So far I have all your regular bolt ons. Headers cai 160 stat. Full exhaust. Cam is 224/230 581. 592 114 comp cam chromoly hardened rods and dual 918's circle D 3000k stall transgo hd2 shiftkit and corvette servo. And tuned. Runs great it will burn all 4 tires for about 5 feet. It's a 2003 SS.
#27
Registered User
that sounds like a sweet ride i hope you get the times you want out of it yeah i think i am going to stay n/a and start looking for a good 6.0 to swap really soon i am going to do a 4l80 swap also so i got to watch my spending. it is tuff to play when you have two kids that you try to buy every thing they want for hahaha
#29
Registered User
thanks alot for the info man you got your ride moving pretty good ithink that 31" is about what my tires measure on 20x9 wheels i don't know if the height would make a difference or not but my truck has 4-6 drop on it
