will a bad cat make engine miss fire
Old 06-10-2009 | 09:09 AM
droppedchev's Avatar
Default will a bad cat make engine miss fire
im having a problem with my 6.0 miss firing at idle it only miss fires the light comes on and blinks once it blinks and i give it some gas to about 1000 rpm the light shuts off so im thinking i have a injector that is dirty or a bad cat any one else have this problem
Old 06-10-2009 | 09:28 AM
SincalT/A's Avatar
Most likely not but,a engine missfire will most certainly cause a bad cat.Check the plugs out see which cylinder is having a problem.
Old 06-10-2009 | 10:01 AM
scott04silverado's Avatar
Prob not a cat problem if it is only misfiring on one cylinder. A bad cat will usually cause an intermittant misfire on that particular bank. Also, a cat problem USUALLY will not misfire at idle, but instead it will under a load. I would check out your injectors, sometimes the back of the fuel rail (on each side) will clog up with trash and debris also.
Old 06-10-2009 | 10:37 AM
yea theres no code on the miss fire it just flashes i just pulled the injectors to see if they were dirty they dont look to bad the plugs are brand new im going to clean the injectors and see if that does it
steves86ta
07-28-2015 10:21 AM
FlowmasterMufflers
07-22-2015 01:29 PM
FlowmasterMufflers
07-22-2015 12:47 PM
FlowmasterMufflers
07-17-2015 03:26 PM
Mossyoakglock
07-17-2015 08:30 AM
Quick Reply: will a bad cat make engine miss fire
