will a CAM ONLY 5.3l run 10's....???
#41
is this a purely track car? something with some time between runs? reason i say is and i dont mean to insult your intelligence if your used to running alcohol cars but you could if you wanted, not run a cooling system. driving the car to the line, burnout, race and return with no rad, water pump, any of that, just a motor filled with water would do you fine. we have seen temps actually drop on the return road. Jet it a little fat, alky tends to be a lot more forgiving then gas and it cools the motor a LOT!
be sure to post up what this thing clicks off
#43
Without a balancer you may have issues at high rpm with bearing life. How are you going to seal the front crank seal? If you end up doing a budget build find some used 4.8L pistons, mill the 862's .030, add a set of used LS6 intake valves, and port them to the limit. Fun project you have there.
#45
Location: Where our street cars are faster than your racecars..Mississippi
FIRST PAS WAS MADE TODAY!!!
60ft.......1.45
1/8et......6.62
1/8mph...102
1/4et......11.40
1/4mph....76
the car is geared for the 1/4 but he let out at the 1/8 just feeling the car out... more passes coming TODAY!!!
60ft.......1.45
1/8et......6.62
1/8mph...102
1/4et......11.40
1/4mph....76
