will a CAM ONLY 5.3l run 10's....???
Old 02-18-2010, 03:44 PM
  #41
schino's Avatar
is this a purely track car? something with some time between runs? reason i say is and i dont mean to insult your intelligence if your used to running alcohol cars but you could if you wanted, not run a cooling system. driving the car to the line, burnout, race and return with no rad, water pump, any of that, just a motor filled with water would do you fine. we have seen temps actually drop on the return road. Jet it a little fat, alky tends to be a lot more forgiving then gas and it cools the motor a LOT!
be sure to post up what this thing clicks off
Old 02-18-2010, 06:47 PM
  #42
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
it is a tube chassis TRACK ONLY car and ALCOHOL is ALL we run in the race cars (we have 4)
Old 02-19-2010, 12:49 AM
  #43
zippy's Avatar
Without a balancer you may have issues at high rpm with bearing life. How are you going to seal the front crank seal? If you end up doing a budget build find some used 4.8L pistons, mill the 862's .030, add a set of used LS6 intake valves, and port them to the limit. Fun project you have there.
Old 02-19-2010, 01:05 AM
  #44
8 Second Club
Flaco's Avatar
i am sure it will do it though, 5.3's are pretty dam stout
Old 02-28-2010, 04:03 PM
  #45
FIRST PAS WAS MADE TODAY!!!
60ft.......1.45
1/8et......6.62
1/8mph...102
1/4et......11.40
1/4mph....76
the car is geared for the 1/4 but he let out at the 1/8 just feeling the car out... more passes coming TODAY!!!
Old 02-28-2010, 04:48 PM
  #46
Nicksilverado's Avatar
60ft.......1.45
1/8et......6.62
1/8mph...102
1/4et......11.40
1/4mph....76
DAMN! good job!
Old 02-28-2010, 05:00 PM
  #47
Wearin' da big hat
00ChevyScott's Avatar
That's got 10s all day.
Old 02-28-2010, 07:36 PM
  #48
skolman91's Avatar
was that on alky or gas?? Def a good start..
Old 02-28-2010, 07:37 PM
  #49
I have a gauge for that
Atomic's Avatar
thats pretty awesome
Old 02-28-2010, 07:55 PM
  #50
PT's Slowest Truck
budhayes3's Avatar
Very nice, on the right track for sure
Quick Reply: will a CAM ONLY 5.3l run 10's....???
