will commit murder over tuning issues!
#32
Originally Posted by Flyer
1020mv is WAAYYY to rich.
what to shoot for? you know once we get this right we are coming to hallsville. he is dying to run it out there. do you have a wideband?
#33
LS1Tech Sponsor
You logging your runs? How much air are you seeing going through the MAF. You should be fine with 42's unless you are pullin more 50lb/min. In that case you are movin a ton of air. I just do not see how the FMU is needed.
#34
You also REALLY need to get your LTFT's negative before you start tuning WOT.
If they're positive, the computer will add fuel on top of what your PE table is adding in.
#36
I AM A MOTHERF*CKER
First -- did you back out the FMU? 5.2 is still a little rich. Try 5.29. 1020mv is about 100 mv too much. Shoot for 900-920mv for now, but you really need to get a wideband reading on your truck to know the sweet spot.
Also, reset your LTFTs and go drive around for a while trying to put the truck through a bunch of engine loads and rpms (without going WOT or stabbing the throttle). After that you're LTFTs will be changed from reseting the IFR. Then try the WOT run.
My LTFTs are 0 to -3 for all cells in closed loop, but I took the time to set the IFR correctly and then tune my VE table using speed density tuning. LTFTs at WOT will lock at zero (anytime you go into open loop).
#40
Originally Posted by CRAZYCUTER4.8
something else I forget to mention, when we were at part throttle & making around 7psi it never cut out until after it got hot.
