will f-body EWP work on 2001 silverado? how is your EWP wired?
Tin Foil Hat Wearin' Fool
It will work just fine, you need to get an extra set of gaskets and double them up so it spaces the pulley out a **** hair more so it will line up with the accessorie drive, we did it on my buddies truck about 2 months ago, he has put about a 1000 miles on it with no problems, with no belts slung or anything.
good information. Quik, do you have it turn on with ignition or with a switch? 1slow, did your friend have an issue with the water neck?
Correct me if I am wrong but the Gen I sbc Tstat will fit right on no problem?
Gen1 works fine, had some sealing issues with the neck but got it fixed. The harness it comes with comes off the fuse box so it comes on with the ignition. Add a manual override along with an override for your efans and you have an awesome solution to cool the motor off BIG time in the pits with the coolant circulating and the fans cooling the water in the radiator
5 year bitches!
5 year bitches!
i had to slightly bend the Tstat to fit but no big issues and used righstuff to seal it and its hasnt leaked yet
SLOPONY
20
10-18-2016 06:05 AM
Mossyoakglock
07-17-2015 08:30 AM
