Will injectors work???
Old 08-10-2004, 10:51 AM
Default Will injectors work???
I am in the process of buying some 42lb svo injectors for my 01 5.3. The plugs look completly different then some of the LT1 injectors I had laying around! Do we have to buy pig tail adapters or what? Please help! This Sucks I need to get my truck tuned!!
Old 08-10-2004, 11:21 AM
GMC SKI's Avatar
The truck connectors are differnt
you will have to buy or find some F -body connectors and wire them into the harness
You will also need to shim up the fuel rail aswell to get the longer injectors to work
Old 08-10-2004, 11:48 AM
greentahoe's Avatar
I just spent $400 and got the 43lb ASM injectors. They are plug and play. I dont want to rig things if there are other options,
Old 08-10-2004, 12:46 PM
9 Second Club
NicD's Avatar
Shitty Joel, I say just hold off until we get the car's WOT fueling dialed in before you change injectors. Your pulsewidths are going to be pretty big right now as it is very rich for safety. They will drop once dialed in.
Old 08-10-2004, 02:41 PM
11 Second Truck Club
L-EATER's Avatar
I have the 42 svo's in both my trucks. The connector should be exactly the same as the LT1's. It is different than the truck connector though. Just splice the proper connectors onto your harness and plop 'em in with a 3/4 spacer between the rail and the intake. You can get the pigtails from MSD if you don't want to go to a salvage yard.
Old 08-10-2004, 02:54 PM
9 Second Club
NicD's Avatar
Fine then Joel, just get the ASM injectors.
Old 08-10-2004, 03:37 PM
If they are the same as LS1 injector connectors, Summitt sells a set of 8 for $15. You'll just need wire.
Old 08-10-2004, 10:39 PM
Default Thanks
Thanks for the help guys. I just went down the street to ASM and got the 43#. (Thanks Green tahoe) I really didnt want to install new connectors. Nic did Kieth get the Dyno in the ground? I want to get this thing dailed in!
Buy the way the 30lb injectors are on ebay now, Heres the item # if any one is interested. 7915599747
Thansk again all.
Old 08-11-2004, 06:30 AM
2ksleeper's Avatar
Just for info the asm's multitec 43# injectors are rated at 58psi where as the SVO 42# injectors are rated at like 42psi. If I remember correctly the 42# SVO injectors will flow 48# at 58psi.
Old 08-11-2004, 08:02 AM
Not to mention the SVO injectors are the industry standard. There is a reason why many GM vehicles have SVO injectors in them. Personally, I would have used the SVOs.
Quick Reply: Will injectors work???
