will running a smaller crank pulley have any effect on S/C boost?
now that I think about it more I think that is correct
my analogy is this:
on a motorcycle if you want to have lower overall gear selections without going into the tranny you have two options......install a smaller front sprocket(i.e. blower pulley) or a larger rear sprocket (i.e. crank pulley)
makes perfect sense know! what was I thinking?
my analogy is this:
my analogy is this:
my analogy is this:
This may sound strange, but you'll have to have a bigger crank pulley to increase boost. The crankshaft will always spin at the same rotational speed. On two pulleys connected by a belt, the angular velocity times the radius of one pulley must equal the angular velocity times the radius of the second one. Thus keeping the same angular velocity on the crank and using a bigger radius makes the angular velocity increase on the unchanged radius on the supercharger pulley. Going to a smaller pulley on the supercharger itself will also increase boost.
blownerator
Uhhhhh, uhhhhhh huh huhuhuhuhhh he said bigger radius.
