Will a stock 99 silverado throttle body fit a tbss intake manifold?
Old 05-18-2009, 05:23 PM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
The TBSS intake is a 4 bolt pattern.
I tried to fit the Volant intake tube to the 90mm this weekend here are some pics.
Old 05-18-2009, 05:37 PM
hirdlej's Avatar
Why on earth would you even want to use a 78mm TB? the whole point of putting the 90mm intake on is more flow. The 78mm TB just creates a bottleneck and is pointless. Just keep the stock intake on if you're not willing to upgrade the TB.
Old 05-18-2009, 06:49 PM
13 Second Truck Club
LS1FREEK's Avatar
The way I see it is that the stock intake don't hardly gain anything with a 90mm TB, so that tells me that the intake itself has a very big part in the air restriction. A polished (by the way, we're gunna do that) 78mm throttle body flows approx 940cfm... That in my opinion is plenty of air for a little 5.3. And I never did rule out the idea of a 90mm TB, I just said we don't quite enough money for that at the time. We want to see the difference in the intake in itself as of now. We kinda ran short of money cuz we're buying tbss intake, tsp cam, hardend push rods, and arp rod bolts.
We're gunna see wht a 5.3 can do, our goal is full boltons, big cam, tbss intake w/90mm TB, milled and slightly ported 706 heads, 3600 edge stall, and 4.10 gears... we're hoping for mid 12's all motor.
His current setup is full boltons(minus under drive), 221 558 cam, 3600 stall, 4.10s, and he ran 13.022@102.4 density corrected... He ran 13.4@99.6 at 2400ft
Old 05-18-2009, 06:51 PM
LS1FREEK's Avatar
Did you have to change alot of stuff to get it on?
Old 05-18-2009, 07:27 PM
Low_LSX's Avatar
90mm T/B
Vette Filter/Regulator Part Number 10299146. It has 2 males and 1 female.
Custom T/B cable bracket.
Intake tubing and pipes.
I added 42lb injectors.
Old 05-18-2009, 07:31 PM
Low_LSX's Avatar
Also for the 90MM to 78MM T/B I think MagnaCharger makes a conversion plate, but not sure if they sell it without their supercharger kits.
Old 05-18-2009, 08:04 PM
hirdlej's Avatar
Sell the ARP rod bolts and get the right TB then. You're wasting your time/money with those.
jdb11386
12-03-2015 09:34 PM
Slammed96
07-27-2015 07:22 AM
04450r
07-24-2015 01:58 AM
fat tony157
07-16-2015 12:35 PM
Black-Syde
07-06-2015 02:12 PM
Quick Reply: Will a stock 99 silverado throttle body fit a tbss intake manifold?
