WIRE DIAGRAM FOR E-FANS
For those whom have not done this mod, and want to save $ on a wire harness for the Fans.
Here is a list of supplies. Wire (12awg), Fuse (30amp) Relay (Bosch) Female spade connectors, butt conectors, and eyelets. Heat activated switch(Hayden Part#019332,019333,019334)
On the relay there are some numbers. Connect them in this order
#30-12v battery
#36-ground
#85-snap switch&switched power on a/c(power wire to a/c clutch)
#87-fused 12v to fan
The wire # 85 diagram goes like this
----a/c clutch
#85---snap switch-------ignition switch
Have Fun
J
#30-12v battery
#36-ground
----a/c clutch
Have Fun
J
Re: WIRE DIAGRAM FOR E-FANS
I couldn't find a Hayden site, but i found one fora an ajustable temp. one on this site. http://www.flex-a-lite.com/auto/electacc.htm Otherwise you can go to Napa, Karparts Pepboys, R&S Straus, or any other chain store, im sure you can find one there. You can buy the relay kit too. But its about $40 for a $2 relay, some wire and .10cent fuse.
Good Luck, J
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Good Luck, J
Wrecker 426
09-30-2015 09:39 PM
