Wiring question for F-Body injectors...
Old 08-29-2004, 07:00 PM
CoonToot's Avatar
Originally Posted by blownZ71
Does it matter what color o-rings are attached to the bottom of the injector. The new ones I have are missing a few and I figured to just use the stock blue ones, is this O.K.? Also, should I use any type of lubricant on the end of the injectors before installing them into the manifold?
I think you are OK if you use the blue O-rings...as long as they are the same diameter and thickness. I dissassembled the fuel rail into three parts and THEN removed each piece individually. Be careful of the O-rings at the junction points, as they tend to come out and drop off. Just be sure to lube the O-rings with vaseline so they don't get pinched when they are inserted into the holes. I didn't do any bending of the crossover on the fuel rail, either. It worked just fine without any bending.
713truck
08-18-2015 09:32 PM
USMCvet0311
08-01-2015 07:45 AM
lsxmalibu
07-29-2015 07:08 AM
Quick Reply: Wiring question for F-Body injectors...
