wiring VSC which A/C wire?
I will be wiring up my VSC and Ls1 fans this weekend. just wondered about the Air cond. signal wire.
what color is it?
is it a positive signal or negative signal (reading the vsc directions i see that it matters)
thanks!
what color is it?
thanks!
Re: wiring VSC which A/C wire?
At the compressor, the wire you want is green .. and that's a positive wire when it's on.
This same wire is under the fuse panel under the hood too. In the middle section, about mid ways, there is a green wire. Start with that one. I also had 2 that were green w/ white tracer, those weren't it.
I'd get a test light or meter out to check it just to be sure anyways.
Its solid green. You can get to it realy easy on the driver side of the engine. Its next to the intake cover. I will take a pic If I can this afternoon to soe you where I spliced in.
Wrecker 426
09-30-2015 09:39 PM
