Wonderin how high I can turn my 5.3 safely.
Old 11-18-2010, 11:25 PM
  #21
Amedee's Avatar
Originally Posted by grey matter 04
no need to spin it 6700 if the cam stops pulling at 6300
Want to know how high you can efficently spin it pay for dyno time and have it retuned
True whats does tps charge?
Old 11-18-2010, 11:27 PM
  #22
13 Second Truck Club
grey matter 04's Avatar
dyno time only $100 for 1 hour
Old 11-19-2010, 12:11 AM
  #23
mhotrodscooter's Avatar
my cam only makes power to 5400rpm & I'm shifting @ 6500rpm..
Old 11-19-2010, 12:17 AM
  #24
4.8chevysilverado07's Avatar
I shift my 4 8 at 6800
Old 11-19-2010, 12:28 AM
  #25
skolman91's Avatar
The dyno numbers never have been right for you imo, either the dyno or operator is off. I think the stock cam makes power up to that point to give you an idea..
Also there's something to be said about helping shift recovery when going higher shift points as well..
Old 11-19-2010, 12:38 AM
  #26
Only dyno to show different was a mustang dyno.. And it was almost 6k.. Sorry
Old 11-19-2010, 12:54 AM
  #27
Wearin' da big hat
00ChevyScott's Avatar
I don't see that cam maxing out at 5400 man. How does it feel as far as powerband goes?
Old 11-19-2010, 01:09 AM
  #28
jrmchevyman's Avatar
Jamedee
Since you run shifts at 6200rpm now try another 100rpm and test that and maybe go from there up to 6400.
You gotta remember this is a forum and like any other forum you need to take everyones post with a grain of salt. Just because people say they run a certain shift doesn't mean you should. Get it dyno tuned so you know everything is right. I just don't wanna see you try and compare to someone elses similar cam that supposedly runs for example 6700rpm shifts, then you go try it and mess your stuff up. Yeah these engines can take abuse but I would stick with a shift that YOU feel safe at.
You just gotta be careful what you read on forums sometimes. One example I see a lot on forums is a lot of guys on many forums says cam swaps on our trucks take 4 hours which is not true lol.. Maybe someone that works on LS engines every day for a living can do it in 6 hours that has the proper tools etc can do it fast but someone that is not familiar with these LS engines may take 3-4 days and you need to make sure you have all the right tools on hand.
Maybe you understand what I'm getting at different people have different experience levels. I just thought this all needed to be said.
Old 11-19-2010, 01:16 AM
  #29
Feels good all the way. I wouldn't go pass 6500 thou, I know shifting @ 5400 sucks, 6000 not to bad, 6500 it's a monster. I really thought it was my exhaust holding me back, but my last dyno was with cutouts open. With no change in power curve.
Old 11-19-2010, 01:31 AM
  #30
Good point..
Quick Reply: Wonderin how high I can turn my 5.3 safely.
