Wonderin how high I can turn my 5.3 safely.
Old 11-19-2010, 01:50 AM
  #31
skolman91's Avatar
Originally Posted by mhotrodscooter
Feels good all the way. I wouldn't go pass 6500 thou, I know shifting @ 5400 sucks, 6000 not to bad, 6500 it's a monster. I really thought it was my exhaust holding me back, but my last dyno was with cutouts open. With no change in power curve.
Went back and looked at your dyno numbers, the second time around wasnt as bad as i thought and look on par or close to it. I still think they should be peaking a little higher than that, but that could be to a couple differnt variables and i wouldnt worry about it. as long as it feels like it just keeps pulling...
Old 11-19-2010, 01:14 PM
  #32
454navyss's Avatar
i took my 5.3 up to about 7400 once while tuning, it was still pulling hard but with about 180k on the stock bottom end at the time (more than that now) i didnt want to push my luck
Old 11-19-2010, 04:03 PM
  #33
iamkeniff's Avatar
i spin mine 6800. it stops making power at 6500 and flat lines till 7k. the truck actually slowed down shifting past 6800. now that i have the 6spd im going to shift at 6500 and leave it alone. im hoping for a 13.2 pass
Old 11-19-2010, 04:08 PM
  #34
14 Second Truck Club
double047's Avatar
What rear gear you running with your 6.2/6L80 combo?
Old 11-19-2010, 05:19 PM
  #35
11 Second Truck Club
joeyc125's Avatar
I agree with most of the people on here, shift higher until you feel it doesn't help. And as for everyone that is telling you to worry about the rod bolts, thats not going to be the the part that breaks. That issue was with the early ls1's having weaker rod bolts that would stretch and wreck the bearings, but this was corrected somewhere around 98-99 or so. The valve train is the part that needs the attention, something nobody has referenced. Not sure what you are running for valvesprings, pushrods, etc, but that needs to be up to par the higher you spin it. I would feel comfortable spinning a bone stock 5.3 up to 6300, with a higher revving cam and good valve springs, hardened pushrods, and the newer style lifters, I wouldn't hesitate to spin it to 7k if it makes power there. Note, I say safe meaning safe, not meaning its going to break 50rpm higher. This are just my opinions I have formed with my experience, I ran my 5.3 stock, with a big cam, stock 6.0l, 6.0l with a tr224, along with helping a few friends set their engines up with different combos.
Old 11-19-2010, 05:36 PM
  #36
Bumpers's Avatar
Originally Posted by jrmchevyman
Jamedee
Since you run shifts at 6200rpm now try another 100rpm and test that and maybe go from there up to 6400.
You gotta remember this is a forum and like any other forum you need to take everyones post with a grain of salt. Just because people say they run a certain shift doesn't mean you should. Get it dyno tuned so you know everything is right. I just don't wanna see you try and compare to someone elses similar cam that supposedly runs for example 6700rpm shifts, then you go try it and mess your stuff up. Yeah these engines can take abuse but I would stick with a shift that YOU feel safe at.
You just gotta be careful what you read on forums sometimes. One example I see a lot on forums is a lot of guys on many forums says cam swaps on our trucks take 4 hours which is not true lol.. Maybe someone that works on LS engines every day for a living can do it in 6 hours that has the proper tools etc can do it fast but someone that is not familiar with these LS engines may take 3-4 days and you need to make sure you have all the right tools on hand.
Maybe you understand what I'm getting at different people have different experience levels. I just thought this all needed to be said.
If it takes you 3-4 days to do a cam swap you need to just call it quits... It took me and a buddy 7 hours for the first time and that was with breaks and stuff and not really bustin to get it done.. The last one went in about 4.5 hrs
Old 11-19-2010, 07:30 PM
  #37
jrmchevyman's Avatar
With 2 guys that know what they are doing I know it could be done fast.
My point is not everyone on the forum is experienced, and you see fellas on every forum giving advice to newbies telling them it will take them 4 hours to do a cam swap in our engines. It's misleading to some people.
If the person is not familiar with these LS engines and does not have the right tools at hand and does not have all the parts ready to go at the garage that time adds up fast. You gotta have all the parts at hand and not be taking several trips to your local parts store for various parts. My advice like stated is make sure you have EVERYTHING ready to go and get ALL the proper tools and no cheap valve spring tools.
I have seen guys that have built older gm small block engines and they attempt to do an LS engine cam swap (never done one before) it might take them a few hours just to do the valve springs or longer. It could be just that they are not familiar with the LS engines or have the wrong valve spring tool. Not everyone can do a cam swap in 7 hours and not everyone should run their engine at 7000rpm's is all I'm trying to say.
Old 11-19-2010, 07:45 PM
  #38
iamkeniff's Avatar
imma stay 4:10s with the new 6spd its not worth swapping gears unless someone had 3:73s with a tru-trac and only had 4500miles on them like mine
Old 11-19-2010, 08:59 PM
  #39
Amedee's Avatar
Well I have patriot xtreme springs and comp hardend pushrods but stock lifters
Old 11-19-2010, 09:03 PM
  #40
skeet's Avatar
youre stock lifters will be fine, thats what most use, you'll be fine if you need to shift at 6800, you can base your shift points off a dyno, find out where your power peaks then shift 200 rpms higher, its pretty much rule of thumb
i shift 7200 daily
Quick Reply: Wonderin how high I can turn my 5.3 safely.
