would dual Bosch 044s in the tank be too much
Yes series = one after another. Parallel = side by side separate supply separate feeds.
Is hooking two 044s in parallel going to do what for me? I'm after the volume more than I am the pressure.
I have a gauge for that
I never understood running pumps in series; you are still always restricted by the volume the pump can flow. Just now it sees a lower pressure so it flows slightly more, but not near the same as twice the pumps flow at the higher pressure like in a parallel setup. If you want volume, do them in parallel.
im doing a surge tank setup with dual 044's are we speak, will turn out to be a KILLER once its done, thats a promise LOL but Im still debating the whole dual pumps vs one single pump, so if it fails I know. This way if one pump fails ill probably lean out and blow something up.
I'm trying to decide if it would be a good idea to have separate relays and fuses for each pump that way if one did fail it wouldn't pull the other down with it or pop the fuse.
lxcoupe
09-06-2017 08:24 AM
