Would you cut stock airbox again
Old 10-06-2007, 09:56 PM
agreif's Avatar
Default Would you cut stock airbox again
Just curious of you that have cut the stock airbox if you would do it again.
Andrew
Old 10-06-2007, 10:12 PM
Mr. Obvious
nightrunner's Avatar
yes... but this time i wouldnt cut my finger with the cut-out tool
not sure how much everybody else was taking out but i cutout the entire passenger fender sideof box out and a 4" hole out of the bottom of box and plate
why do you ask?
Old 10-06-2007, 10:35 PM
agreif's Avatar
I thought I had read in the past with people not liking the mod after the fact. Why did you cut the whole outside panel out? Wouldn't that let hot engine bay air in as well? Everyone pasically takes some dryer tubing down to the tow hook area, eh?
Old 10-07-2007, 08:53 AM
Mr. Obvious
i havent made a ram air valence yet but plan to at some time. some have used the flexible dryer vent hose, and others have used 4" plastic PVC
i cut the entire side out because it got rid of all of the baffles and scoops and such. its butted right next to inner side of the front fender, so no hot air gets in. and the hole in the bottom faces a space where freeflowing air is. its separated from the hot engine bay by the foam heat shield thing and separated from direct water contact from the tire by the inner fender wheel well
Old 10-07-2007, 10:27 AM
TXsilverado's Avatar
i used a 3" circle saw to punch a hole in the bottom side of my box. also went through the metal plate below the box. then hooked up a volant air system below it. i would do it again.
Old 10-07-2007, 07:21 PM
5.3LGMC's Avatar
I did exactly what nightrunner did and yes i would do it again....i also modified my intake tube going to the throttle body....i cut all the baffles off of it and then fiberglassed and smoothed the entire thing to create a normal tube.
Old 10-07-2007, 07:32 PM
Mr. Obvious
i just got a new intake tube made of steel and used silicone couplers and a rubber elbow
Old 10-07-2007, 07:48 PM
kw05silverado's Avatar
i took a paddle bit and made several holes that became a single 3 inch hole.then a few days later i took the whole bottom half off and took some small screws and made the filter stay flush with the top half. i was
but it worked.
Old 10-07-2007, 08:10 PM
closet red neck's Avatar
This is what I did but I installed a 3" sewercap so in rainy weather, I could plug up the Volant ram-air. With that being said, I also smoothed out the inside if the stock air that's up against the fire wall. I made a meyal plate to block off the fenderwell hole. So basically when the ram-air is "open"(3" sewer plug is out), the plate blocks the fenderwell hole. When it rains I plug the hole(3" sewer plug is in) and remove the metal block off plate.
This must sound complicated.........
James
Old 10-07-2007, 08:30 PM
James
i understand what your sayin but it sounds like more crap than its worth. sounds like we have the same EXACT custom intake setups. upd lid with volant built to the factory box. ive never had a problem with rain or hitting big puddles. and capping up the fender and uncapping the sewer drain dosent seem like it would benifit you any. i doubt you can build enough positive pressure in the intake system to actually gain anything from it. i did it just to open up the box and supply plenty cool air.
Quick Reply: Would you cut stock airbox again
