WTF!!!!!!! Hemi Pulled my 2500!!!!!
#21
I think everyone hit it on the head good. First you jumped in the throttle spinning the tires. Plus hes got 20 inch tires that are decently wide giving him good plantation for traction. And I totally agree with 8100, if his hitch is higher it will pull your rear upwards giving you less traction. Plus he had more weight in his bed.
#22
8 second mod
You guys are giving me a vote of confidence!!
my plan is this, drop my torsion bars about 3", take my tire press from 50- 30, throw 300 pounds of sand over my axle, (try to throw a 50 lb bag of sand under the hood for the front tires, little cheeting! hehe), and hook up with a tape mesure! even on flat ground. hell i might even throw som tration compound on the tires right befor i get there!!!
you guys think with the above and a fast roll on the gas in 4 low will work?
i cant loose again!!! also, i was thinking a quick hp or so i should pull my t-body, PP it and then do the coolant by pass! Also will an ls1 t-stat fit on my truck? i have a 160 stat off My Z from when i put the electric pump on. (honastly, ive never even looked to see if they are the same)
#23
Power Is Not The Answer I Also Have 2500 Hd I Pulled More Trucks Without My Charger More Power U Have Better Chance Of A Spin Out Tighten The Chain Give Enough Gas To Hold Yourself Let Him Start Spinning After He Starts Spinning Gas It Throttle Is The Enemy In Tug O War I Have Pulled 1 Ton Duallys Before Because They Got Throtle Happy A Hemi Shouldnt Have A Chance
#26
If It Dont Work Out For You This Time Let Me Know Tell Me What Happend Ill Help You Pull This Guy If I Have To Come Wherever You Are And Do It If He Beats You Again Check His **** Caus He Has To Be Cheating Good Luck But You Shouldnt Need It
