XLR8NSS, PARISH 8, Got injectors in, more ???
Adkoonerstrator
Re: XLR8NSS, PARISH 8, Got injectors in, more ???
What did your MAF reading say in lb/min? Do you have a inline fuel pump? Also, can you log the injector pulsewidth with EASE? If so check the duty cycle % on those injectors.
Sounds like you might be maxing out the stock pump or injectors(doubtful)
Add fuel above 4000rpm in the PE table and see if that helps. Be very careful though.
Checked my fuel pressure at wot in second gear after that happened, and it stayed steady at about 61psi. Didn't check 3rd though. I do have the inline pump that ATI supplies, but haven't verified if its working lately. I know it used to keep up when I had the FMU last week.
Adkoonerstrator
Yeah, now is the best time to do those WOT blasts.(Late at night. ) Well, it's late here anyway.
XLR8NSS- my maf reads 40.6 lb/min max. (still using the 8psi pulley) With my MAF readings I'm pretty sure the injectors aren't maxed. Havent logged the duty cycle though.
I'm gonna have to verify that the inline pump is working, and do a third gear test I guess.
Is it possible for the pump to keep up in 1st and second but not 3rd?
single digit dreamer
are you loging both the wideband and atap? both of mine were set up for the serial port but i was able to get this adapter that goes from a serial port to a usb port and it worked for the fjo. it wouldn't work for atap though but i have an old version of atap.
