XR265 vs XR259 in a 5.3L
9 Second Club
Do you have the actual dyno run files that you could post? Do you have the graph over RPM instead of speed? I guess i could calculate the peaks with a calculator if you could post your rear tire height. Assuming a 29.5" tall tire it looks like peak torque around 4100 rpm and peak HP at 5800 rpm but the graph doesn't go far enough to get a good picture of what happens after that. Heck it may still be going up slightly.
Yes this was on stock tires, 255/70. I should be going to the shop today to drop off a cam, I'll see if I can get an RPM graph (I want one too). I trapped 96mph on motor so it's closer to 300rwhp now.
heres a pdf of a bunch of their cams for these motors
http://www.compcams.com/technical/Ca...07/172-175.pdf
9 Second Club
54-408-11 XR259HR 259/265 advertised 206/212 @ .050 .515/.522 112° LSA
54-412-11 XR265HR 265/271 advertised 212/218 @ .050 .522/.529 114° LSA
The hi-lift version of the 265 that I didn't list above looks to be a disaster for a 5.3L and isn't even that great on a 5.7L-6.0L motor.
PT's Slowest Truck
![Thumb](https://www.performancetrucks.net/forums/images/smilies2/thumb.gif)
I should be familiar with that first grind lol
