XR265HR in a 5.3 dyno graph and thoughts
9 Second Club
It's pretty much the same. After I did the cam I drove the same stretch of the freeway that I always do and reset the average on the DIC and it read pretty much the same afterwards. Driving in the city with stop and go was pretty much the same as well.
9 Second Club
Like I said, 9.5 to 1 compression is pretty low and you really aren't going to gain much if any by running a higher octane gas and trying to feed timing into a setup that is pretty much optimized for 87 octane to begin with. Only time I have seen good gains with tuning for 91 octane is with the higher compression versions of the motors in the trucks.
I guess it's going to vary from person to person. I'm curious to hear the opinion from people who have tuned hundreds of trucks. Speaking from personal experience I was able to run quite a bit more part throttle and WOT timing switching from 87 to 93. I don't have a ton of track time but efficiency was greatly increased. Under the same conditions I saw almost 3 mpg difference on the highway.
9 Second Club
I've been doing this for 8 years now and honestly I have lost count of how many vehicles I have tuned. I have tried adding timing all over with higher octane and just doesn't see a big benefit regardless if it takes the timing or not on the lower compression stuff. I saw all of a half mpg difference in gas mileage by adding up to 8 degrees or more in the part throttle areas and hardly any difference on the dyno at WOT either. I am talking about the difference between tuned 87 vs 91, not what it comes from the factory with vs what you can add because that is a good amount. Then again I am not selling people 91 octane tunes and claiming big numbers so I have no motive behind advertising.
As far as knock, I'm running 29* at WOT. I don't see knock until 32* or so (I'm aware of the law of diminishing returns on the matter) . I have not tried to fill up with 87 to see if it sees knock or not. Perhaps that test will happen when the local track opens up.
