XR265HR in a 5.3 dyno graph and thoughts
#21
I wasn't aware of your credentials, my apologies . It's a pretty interesting topic. I may start a new thread to see what everyone else has to say. Like I said, I have no track times to compare.
As far as knock, I'm running 29* at WOT. I don't see knock until 32* or so (I'm aware of the law of diminishing returns on the matter) . I have not tried to fill up with 87 to see if it sees knock or not. Perhaps that test will happen when the local track opens up.
I just see no real gain after a certain amount of timing on these lower compression truck motors and don't see a big benefit to running premium in them after LOTS of time and testing.
#22
Very nice gains, and you didn't have to give anything up down low either. Interesting about the low octane/ 26* of timing also, I'd be interested to hear more about this.
#23
I guess it's going to vary from person to person. I'm curious to hear the opinion from people who have tuned hundreds of trucks. Speaking from personal experience I was able to run quite a bit more part throttle and WOT timing switching from 87 to 93. I don't have a ton of track time but efficiency was greatly increased. Under the same conditions I saw almost 3 mpg difference on the highway.
--------Test1------Test2-----Difference
RPM----HP---TQ---HP---TQ--HP--TQ
2,500--139--291--141--296---2---5
3,000--172--301--173--303---1---2
3,500--208--312--209--313---1---1
4,000--250--328--252--331---2---3
4,500--290--338--291--340---1---2
5,000--324--341--327--344---3---3
5,500--340--325--344--328---4---3
6,000--344--301--353--308---9---7
#24
As far as the lower octane timing stuff goes I just don't usually see these 9.5:1 motors being octane limited much if at all. Meaning you can feed timing in to them at 87 octane and make just about as much power as you can with 91 octane. Just adding timing for the sake of running higher octane doesn't necessarily give you a noticeable gain when you are not octane limited. IE it may knock above 27 deg of timing on 87 but is it really making more power if it's set to 32 deg on 91 octane? Not in my experience but of course every combo is different but I am just talking in general.
#25
Just a few more things....
The stock 24.5 lb/hr injectors that are in my truck are very much at their limit. I am seeing ~95% at 6300 rpm at a 12.5:1 a/r ratio. I am not really worried about any problems arising from this but I am going to be looking for some bigger factory injectors to swap in at some point. Going to the marine 44 lb/hr injectors seems like a bit of overkill but I don't really see any other injectors in the mid 30 range that would work other than maybe stock car LS2 injectors but even then those aren't the right length, etc correct?
I found my good mic last night so I will probably try and take an idle clip tonight or tomorrow if anybody is interested in what it sounds like.
#27
Ahh, but I won't have much luck finding those around here since most people don't pull them out like the vette and GTO crowd does for bigger ones. I am pretty sure I know of a couple of sets of the stock car LS2 injectors at some of the local shops that I can get my hands on for cheap, just don't know if they are a direct swap like the 8.1L injectors.
#28
#30
Yea, just looked at some LS2 car injectors and that's a no go. Only reason I wanted the LS2 car injectors is because I could take a set or two for free.
I will look in to the 8.1L injectors, thanks for that link on Ebay. Guess I just have to figure out what I really want to do with the near future and if it's worth it to get the 31# injectors or not.... cough... TVS...
