XR265HR in a 5.3 dyno graph and thoughts
Old 03-09-2009, 09:00 AM
  #51
greenz71's Avatar
Hey Sharky did you have any issue with the LS6 springs? I thought they were only good to .550? That may change my mind on the high lift if I can run LS6 spring.
Old 03-09-2009, 09:41 AM
  #52
53RUSSELL's Avatar
I have yellow ls6 springs and I have .563 on them. I thought the max was .570 or .580.
Old 03-09-2009, 10:55 AM
  #53
I Like Gold!!!
BBLS1's Avatar
i've heard .570 was the max.
Old 03-09-2009, 11:09 AM
  #54
PT's Slowest Truck
budhayes3's Avatar
Well, seat pressure makes a difference with the LS6 springs also. If the lobes have real agressive ramp rates that require more seat pressure, I wouldn't recommend the LS6 springs. I know that some Lingenfelter cams have lifts in excess of .571 and they recommend LS6 springs...the cams are ground by Comp, but I'm assuming they are XE lobes. Also, FWIW, Zippy has a Comp 222/224 .56x/.56x 112 that he uses LS6 springs with, and he's doing OK with it. I think that the LS6 spring closed seat pressure is around 90, while the aftermarket springs such as the PAC beehives and junk Comp 918 have a closed seat pressure around 130. I believe that the LS6 open seat pressure is up over 3xx, not sure on the others.
Old 03-09-2009, 12:08 PM
  #55
Yeah I asked zippy what he thought about the ls6 springs and he said it was cool to run them. I know there is alot more aggressive cams that people are using the ls6 springs with.
Old 03-11-2009, 01:10 PM
  #56
9 Second Club
NicD's Avatar
Originally Posted by 006rcsb
how about that vid? maybe of the idle and some nice revs, and maybe a lil tire roasting? you know you want to....
I will have some time tonight I think to make a video showing the idle and maybe a few revs. Probably no tire roasting though as I just got the 3.73s with the truetrac in. Maybe I'll take it to the track on friday to see what kind of times it can do although it will probably be not that great considering it's Arizona.
Old 03-11-2009, 06:15 PM
  #57
04herod's Avatar
would luv 2 hear it 2 been thinkin on this cam and the high lift 4 a week or so now but this 1 is bout what i am want with my 2500 stall and ive already got the z06 spring
Old 03-11-2009, 09:42 PM
  #58
9 Second Club
NicD's Avatar
Alright, it got late so I didn't throw any revs or anything but this is just the truck idling so you can hear what the small lope sounds like. It was recorded from about 5 feet behind the truck. The exhaust is a custom 2 magnaflow muffler setup in series, single 3" otherwise the vid is pretty self explanatory.
http://gonicd.com/videos/xr265_idleonly.wmv
Old 03-11-2009, 09:48 PM
  #59
006rcsb's Avatar
music to my ears!
Old 04-01-2009, 09:10 PM
  #60
jiar577's Avatar
NicD, I installed the same cam on my '06 5.3 over the weekend. You told me before you set your shift points at 6300rpms, is that for all the gears?
Also, I've read mixed comments on removing the cats, some say removing them hurt lowend. Did you removed them? I'd love to see real info on cats vs no cats on the lowend.
Thanks
Quick Reply: XR265HR in a 5.3 dyno graph and thoughts
