youve got to be kidding me...
If you want a dependable truck, that is fun to drive, tune/converter is the way to go. It will be a night and day difference.
im ready to hit the track finally.this truck project has taken alot longer to get ready than my car projects in the past. got my truck in july. its a 2012 rcsb ls worktruck 5.3 6speed. mods are knn drop in airraid tube ported & polished 90mm tb fast lsxrt 102mm slp udp kooks longtubes w catted ypipe into 3inch by 18inch summit glasspack with turndown before axle. 1.8 yella terra ultralite rockers circled 3000-3200 278mm stall 4.10 richmond accel gears tuned by area 47.
What did you spend to get there?
You want 12s in a 4.8L crewcab? Hmmmm
You need spray forced induction or a bigger motor to get 12s in a 2010 crewcab.
Solid build to get you there....
Isky triple twelve cam contact stock4.8
Circle d 3400 stall
4.10s
Trick turbo kit stage 3.
Fuel system to support big power.
Custom tune
Weight reduction
Circle d 3400 stall
4.10s
Custom tune
Weight reduction
