Yukon denali build
Yukon denali build
Well I feel I have a good starting point for building something fun to drive I have a 2004 yukon denali awd and 6.0, I wanted to get a few ideas on what other supporting mods I need for what I want to do so I can go ahead and start collecting up the stuff. For the majority of the power I want to use the trick performance turbo kit, I also want to add a mean cam to it, nothing huge just something with some sound and will benefit with the turbo. The kit I guess I need is the 76mm kit, my question is what kind of injectors do I need? and do I need to upgrade my fuel pump Im only planning on 8psi on the stock block and heads, is that a good safe PSI? Do I need to upgrade my valve springs? also is there any other odd and end thing I should add to help maybe a torque converter? What would the projected HP number be on a build like this?
5.3Caprice
11-07-2015 08:56 PM
FlowmasterMufflers
08-14-2015 12:47 PM
350SS
07-11-2015 12:34 PM
