zero oil pressure.......sh!t
zero oil pressure.......****
the gauge does not move when i first start it up. shows normal numbers after a few minutes. dont hear any bad noises, no drips, etc. going to test pressure tomorrow @ the oil filter connection. hopefully just a sending unit. anyone experienced this?
was out on a cruise for most of the day...beat on it, but no more than i always do. pulled into the gas station to fill before putting her away and when i started back up...gauge at 0 and the low pressure waning on the DIC.
only change in the past week was swapping my vette TAC/pigtail for an x-link. already had the 90mm. cam has been in for 6 months. i am gonna plug in with a TECH2 tomorrow and also a manual pressure gauge that spins on where the oil filter mounts. i am hoping its the sender.....but how the gauge shows pressure after a mile or so is strange.
maybe the oil pump is being stubborn, maybe a bearing, maybe a sender. damn senders are a pain in the *** to get to, especially with the radix...well, easier than a new bottom end. or maybe an excuse to go 402?
Well there's not really a ton of stuff that can go wrong inside an oil pump. I had the pickup tube o-ring go bad(A nightmare for Cody and Me).
Possible things it could be:
O-ring on oil pump(most likely)
oil pump bad
sender bad
Cam bearing bad
I'll think of more theories if they should arise in my head.
oil pump bad
sender bad
Cam bearing bad
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
09-25-2015 12:36 PM
69z-28
09-21-2015 07:31 AM
