FS: Aeromotive Adjustable Fuel Pressure Regulator
For Sale:
Aeromotive adjustable fuel pressure regulator with boost/vac reference. From their website:
Big performance in a small package. The Compact EFI Regulator is designed for applications producing up to 1,000 HP where space is at a premium. Ideal for EFI fuel delivery systems that are limited to one regulator inlet port.
• Adjustable from 30-70 PSI.
• Equipped with removable AN-6 male fittings for inlet and outlet ports, eliminates the need to buy additional fittings and O-rings.
• Dedicated, 1/8” NPT gauge port located opposite the side inlet.
• Fuel pressure rises on a 1:1 ratio when referencing boost.
This regulator performed flawlessly on my set-up for about 4k miles. The condition is as close to new as you are going to find, not even a scratch on it. -6AN Fittings are included however the plug for the fuel pressure gauge port is not. Not an issue if you plan to install a gauge! If not, the 1/8” NPT gauge port will need a plug. you can buy at places like summit for about $2, or go to Home Depot and buy a brass plug for a dollar. I will give a look as I may have one laying around.
$100.00 Shipped in the lower 48.
![Name: IMG_1347.jpg
Size: 66.1 KB](https://www.performancetrucks.net/forums/attachments/gm-parts-classifieds-23/125027d1501306156-fs-aeromotive-adjustable-fuel-pressure-regulator-img_1347.jpg)
Ill talk to zippy tonight and see if I can use this for my setup. I'm about to upgrade to a Walbro 400 and some deka 80s and as far as I understand I won't be able to use my factory in tank regulator anymore. Just not sure what else ill need to run this on my setup. If you could offer any guidance as you're more advanced with this stuff than me hit me up, 9039189380.
If you are removing the in-tank regulator and doing a custom return style with aftermarket rails and-AN fittings, this guy is for you. Just hang it off the return rail and dial in the pressure you desire.
BTW, I found the plug for the fuel pressure gauge port so I will include it.
Probably not custom rails just yet but I am going to have to modify my fuel system some. I figure I can adapt to make it work with what I have now and not have to upgrade again later on down the road when I do go all out on a fuel system. What's your PayPal, ill take it.
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
