Hawk Ferro Carbon Rear Brake Pads
Brand new set of Hawk High Performance Street compound Rear Brake Pads. Never been installed. I went to a set of Baer 14" rotors and these pads don't fit my application.
They have been sitting in my garage about 2 years so somebody gets a deal.
Retail $95. $50 shipped. Buyer responsible for correct application. If they do not fit, you must acquit...
Thanks, Rick
Vehicle Applications for Hawk Performance HPS Brake Pad HB385F.640
Year Make Model Description Position
2000 Chevrolet Suburban 1500 (1/2 Ton) - 2WD Models w/ Rear Disc Brakes & w/ Limited Slip Axle Rear
2000 Chevrolet Tahoe 2WD All Models w/ Rear Disc Brakes Rear
2000 Chevrolet Suburban 1500 (1/2 Ton) - 4WD Models w/ Rear Disc Brakes & w/ Limited Slip Axle Rear
2000 - 2002 GMC Yukon, Denali XL (1/2 Ton) 2WD & 4WD Models w/ Limited Slip Axle Rear
2000 GMC Yukon, Denali 4WD - Except Yukon XL Rear Disc Brake Models w/ Limited Slip Axle Rear
2000 GMC Yukon, Denali 2WD - Except Yukon XL Models w/ Rear Disc Brakes Rear
2000 Chevrolet Tahoe 4WD Rear Disc Brake Models w/ Limited Slip Axle Rear
2001 - 2002 GMC Yukon, Denali 4WD - Except Yukon XL Rear Disc Brake Models w/ Limited Slip Axle Rear
2001 Chevrolet Silverado 1500 - 4WD 2 Door Extended Cab Models Rear
2001 GMC Yukon, Denali 2WD - Except Yukon XL Models w/ Rear Disc Brakes Rear
2001 GMC Sierra 1500 - 4WD 2 Door Extended Cab & C3 Models Rear
2001 - 2002 Chevrolet Tahoe 4WD Models w/ Limited Slip Axle Rear
2001 - 2002 Chevrolet Suburban 1500 (1/2 Ton) - 2WD Models w/ Limited Slip Axle Rear
2001 Chevrolet Tahoe 2WD All Models Rear
2001 - 2002 Chevrolet Suburban 1500 (1/2 Ton) - 4WD Models w/ Limited Slip Axle Rear
2002 GMC Sierra 1500 - 4WD 2 Door Extended Cab Models w/ 4 Wheel Steering Rear
2002 Chevrolet Avalanche 1500 Models w/ Limited Slip Axle - Dual Piston Rear Caliper Rear
2002 Chevrolet Tahoe 2WD Classic Style Models Rear
2002 Cadillac Escalade All Models Rear
2002 Chevrolet Silverado 1500 - 2WD 2 Door - Ext Cab Models w/ 4 Wheel Steering Rear
2002 GMC Sierra 1500 - 2WD 2 Door Extended Cab Models w/ 4 Wheel Steering Rear
2002 Chevrolet Silverado 1500 - 4WD 2 Door - Ext Cab Models w/ 4 Wheel Steering Rear
2002 GMC Yukon, Denali 2WD - Except Yukon XL Classic Style Models Rear
2003 - 2004 Cadillac Escalade 4WD Models - Including ESV & EXT Models Rear
2003 Chevrolet Silverado 1500 - 2WD 2 Door - Ext Cab Models w/ 4 Wheel Steering - 330mm Rear Disc Rear
2003 - 2006 Chevrolet Tahoe 4WD All Models Rear
2003 GMC Sierra 1500 - 2WD 2 Door Extended Cab Models w/ 4 Wheel Steering ~ 330mm Rear Brake Disc Rear
2003 Chevrolet Silverado 1500 - 4WD 2 Door - Ext Cab Models w/ 4 Wheel Steering - 330mm Rear Disc Rear
2003 - 2006 Chevrolet Suburban 1500 (1/2 Ton) - 4WD All Models Rear
2003 GMC Sierra 1500 - 4WD 2 Door Extended Cab Models w/ 4 Wheel Steering ~ 330mm Rear Brake Disc Rear
2003 - 2006 GMC Yukon, Denali 4WD - Except Yukon XL All Models Rear
2003 - 2006 Chevrolet Avalanche 1500 4WD Models Rear
2003 - 2006 GMC Yukon, Denali XL (1/2 Ton) 4WD Models Rear
2004 Chevrolet Silverado 1500 - 4WD Crew Cab Models Rear
2004 GMC Sierra 1500 - 4WD Crew Cab Models Rear
2004 Chevrolet Silverado 1500 - 2WD Extended Cab Standard Duty Models w/ 4 Wheel Steering Rear
2004 GMC Sierra 1500 - 2WD Standard Duty Extended Cab Models w/ 4 Wheel Steering Rear
2004 Chevrolet Silverado 1500 - 4WD Extended Cab Standard Duty Models w/ 4 Wheel Steering Rear
2004 Chevrolet Silverado 1500 - 2WD Crew Cab Models Rear
2004 GMC Sierra 1500 - 4WD Standard Duty Extended Cab Models w/ 4 Wheel Steering Rear
2004 GMC Sierra 1500 - 2WD Crew Cab Models Rear
2005 GMC Sierra 1500 - 2WD Heavy Duty Crew Cab Models w/ Quadrasteer Rear
2005 Chevrolet Silverado 1500 - 4WD Heavy Duty Crew Cab Models w/ Quadrasteer Rear
2005 GMC Sierra 1500 - 4WD Heavy Duty Crew Cab Models w/ Quadrasteer Rear
2005 - 2006 Cadillac Escalade 4WD Models Rear
2005 Chevrolet Silverado 1500 - 4WD Extended Cab SS Models w/ 6.0L V8 Engine Rear
2005 Chevrolet Silverado 1500 - 2WD Heavy Duty Crew Cab Models w/ Quadrasteer Rear
2006 GMC Sierra 1500 - 4WD Extended Cab SS Models w/ 6.0L V8 Engine Rear
2006 Chevrolet Silverado 1500 - 4WD Extended Cab Models w/ 6.0L V8 Engine Rear
2006 Chevrolet Silverado 1500 - 2WD Extended Cab SS Models w/ 6.0L V8 Engine Rear
2006 GMC Sierra 1500 - 2WD Extended Cab SS Models w/ 6.0L V8 Engine Rear
Thanks, Rick
Steve-O-08
04-19-2018 09:32 AM
SLOPONY
20
10-18-2016 06:05 AM
mrgrim
07-08-2015 08:12 AM
