Tekonsha P3 Electric Trailer Brake Controller
The P3 controller is designed for use with electric and/or electric over hydraulic trailer braking systems. A simple switch on the unit allows the user to toggle back and forth between the two systems. The Tekonsha P3's LCD display features a distinctive look with multiple color and contrast options and includes a highly advanced, easy-to-understand roadside diagnostics display. The P3 advanced diagnostics not only notify you of potential problems, it can tell you where to begin trouble shooting.
Features:
•Applies power to the trailer brakes in proportion to vehicle's deceleration.
•No level adjustment necessary - it adjusts itself to varying terrain as you drive.
•Works proportionally in reverse - great for backing into tough spots.
•Designed for use with electric over hydraulic trailer brake systems.
◦Works equally well on standard electric trailer brakes.
•Digital display depicts voltage delivery to trailer during braking.
•Continual diagnostics check for proper connection, shorted magnet condition and much more.
◦Easy to read and understand diagnostic display
•"Boost" feature gives users the ability to apply more initial trailer braking power when towing heavier trailers.
•Power-saving mode reduces drain on battery when vehicle is not in use.
•Unique pocket mount allows for flexible mounting options.
•Quick and easy disconnect feature allows user to remove and store the control when not in use.
◦The P3, along with the Tekonsha Prodigy and Primus, offers a replacement wiring harness (sold separately) to move the controller easily from one vehicle to another
•Rotary style manual brake adjustment lever is easily accessible under the controller unit.
•Customize the LCD display by choosing language, color and contrast options.
◦Language options: English, French, and Spanish
◦Color options: blue, light blue, cyan, green, light green, orange, magenta, pink, and white
•Limited lifetime warranty
Specs:
•Dimensions: 3-5/8" (W) x 4-5/8" (L) x 1-3/8" (H)
•Boost levels increase power up 0%, 13% and 25%
•180 degree vertical plane operating range
◦Can be mounted between -90 degree (straight down) and 90 degree (straight up)
•Made for up to four-axle trailer brake systems (8 Brakes)
•Diagnostic Troubleshooting displays: Battery Voltage, Stop Lamp Voltage, Output Voltage, Output Current
•Diagnostic Warning Signs: Open Ground, Overload, Output Shorted, Power Loss, and No Trailer Connected
I paid $220 New, Still in New condition $130 shipped.
Features:
Specs:
