01 Silverado overcharging?
Old 03-05-2012 | 07:07 PM
Ryan-P's Avatar
Default 01 Silverado overcharging?
Noticed today the voltage guage was around 16 17 volts. Any common problems cause this? Truck is 4.8 stock 104k miles.
Old 03-05-2012 | 07:39 PM
Mangled03gmc's Avatar
Baltimore Whore
Regulator in the alt could be going.
Old 03-06-2012 | 01:03 AM
Ferocity02's Avatar
What's a typical voltage? Mine at idle is just a hair above 14V, and 15.5 above idle. I just swapped in a 145A alternator. This is using the volt gauge on the dash, is there a better way to read the voltage?
Old 03-06-2012 | 02:24 AM
DR132's Avatar
factory voltmeters are not to be trusted for accuracy. this goes for all makes and models, they give you a good idea if your charging or not but that's about it, not to used for any real diagnostics. get a handheld voltmeter or multimeter and test the voltage at the battery or between your positive power block and a good ground point, voltage on a healthy battery at idle without any serious draws on it should be 14.4 give or take a little bit...
Fullpower (08-15-2022)
6LITEREATER
01-26-2016 05:21 PM
nickpc82
11-02-2015 03:49 PM
85SS/85GN
08-07-2015 05:30 PM
Shtbox
08-02-2015 11:52 PM
Offroadunleashed
07-20-2015 03:25 PM
