01 Tahoe please explain when to use which 4WD option ?
can anyone explain when to use the different 4wd option on a 2001 tahoe ?
also anyone know what speed u have to be going to switch from 4wd to regular or vice-versa ?
thanks
thanks
4-HI on the silverados will go through anything but if you are trying to show off you can get through a mudhole real fast just put in 4 low youl go through anything with speed, here some advice full throttle the tahoe when going through a mudhole higher than your knees and youll make it . laters
10 Second Club
Originally Posted by chevymec
You can go from 2-hi to 4-hi any any speed
4-lo , you need to stop before engaging and you must have it in park or Neutral.
Auto 4wd can be engaged at any apeed.
