02 to 06 Tail Light Swap Problems! Drivers side doesn't work
I have a 1999 that i put a 2000 fleetside bed and i swapped the tail lights for the nice lookin 2006 tails. I got the tail lights and wiring harnesses off an 06 truck. The passengers side seems to plug in a little better than the drivers side and it works fine. I thought the drivers side could have a bad harness or that the bulbs were bad so i so i swapped out another harness with different bulbs and it still doesn't work. What's wrong or what else could it be? The little plate that you plug in the harnesses up under the bed, could it be bad or does it need to be swapped out with a newer one to work with the newer harnesses? I just don't know
Import Moderator
It wont snap in if thats what you are referring to... I know it feels like it should snap in or click when you have them properly installed, the dont though, Ive swapped to these on 4 different truck, all of which felt like they werent properly installed. Now if your bulbs arent working thats a different story!
I don't know i never had them running! I know that sounds funny but i swapped my sportside for a fleetside and never had the lights running on the truck until now. What could be the problem? I don't see any pieces of the connector broke or messed up.
GreyChevy
07-07-2015 08:57 PM
