04' Hoe, Rear heat not working....
Old 11-06-2008 | 06:06 AM
Raven02TA's Avatar
Default 04' Hoe, Rear heat not working....
Bought my Tahoe late last year and everything has been working fine until just a few weeks back, it seems no matter what i do i cant get the rear heat to blow hot.... it stay freezing *** cold. if i didnt have my daughter i wouldnt worry about this issue but i would like to have it warm back there for her this winter.
Anyone have this issue? know how to fix?
Old 11-06-2008 | 08:36 AM
Sounds like the Rear Temprature Door Actuator. Part # 89018375
Old 11-06-2008 | 11:48 PM
Raven02TA's Avatar
ok, thats a lead, is there a way to diagnose? and where is it located?
Old 11-06-2008 | 11:52 PM
TX Tahoe Z71's Avatar
Now that's service right there!
I had the opposite problem with mine (only ambient air, no A/C), turns out some junk was clogging one of the hoses and had to be flushed out. Hope it works out for you.
Old 11-07-2008 | 08:16 AM
LOL....thank you sir! We see several problems out of the rear ac and climate control in the Tahoe/Yukons and Suburbans.
Old 11-07-2008 | 08:20 AM
You can check the voltage across the actuator upon operation to see if it's working or not. Sometimes they just don't open all the way and hang up in the middle.
It's kinda hard to describe where the thing is. It is located on the rear section of the rear Aux AC Module in the left side inner quater panel trim panle. There are 2 identical actuators.
If you have a fax machine, I can fax you the picture.
Old 11-07-2008 | 07:47 PM
I had to replace the Aux AC Module in mine. I had an AC shop scan the BCM to figure this out. FYI
Old 11-10-2008 | 05:00 AM
Raven02TA's Avatar
thanks all for the help, ill make an attempt this weekend to dig in and see whats going on in there.... hopefully it wont be too cold....
thunder550
10-08-2015 05:53 PM
Verz
08-21-2015 07:40 PM
DarkhorSe_SS
08-20-2015 09:58 AM
terravast4
08-12-2015 03:07 PM
