05 6.0L MAF connector part #
Old 07-28-2005, 07:10 AM
  #91
MOOBIES Moderator
Scream's Avatar
99-02 GMC SLE chrome door/body trim (2 ea)
15744376
15744375
15744371
part numbers are same for L and R
Old 08-04-2005, 07:12 PM
  #92
SSlow 4.8's Avatar
15735965 which is the radiator cover doesnt seem to work on gmpartsdirect.com anyone know the new part number?
Old 08-10-2005, 12:45 AM
  #93
OCBC's Avatar
All the previous numbers for the GMC Denali front projector headlights are not working on GMPARTSDIRECT. Do they not carry those or has the part number changed?
Old 08-21-2005, 11:32 PM
  #94
Hey i need the part numbers for the front bumber lower valance with holes cut for the fog lights, and the fog light kit. I also need the black plastic molding peice that goes on top of the bumper. for a 05 silverado 1500.
thanks
Old 08-22-2005, 03:03 PM
  #95
Rammer's Avatar
Fog Lamps - 12499673 (Except vehicles w/ RPO Code B4U, TS9 and YE9)
Cut through the fog with these strong lamps. Illuminating beam minimizes glare. All mounting hardware, wiring harness, multi-function cargo / fog lamp switch and front lower fog lamp mounting facia are included.
DESCRIPTION: FOG LAMP PACKAGE WITH LOWER DEFLECTOR 189.00 At Gm Parts Direct
Old 10-02-2005, 03:12 PM
  #96
Onyx 02's Avatar
15171404 Upper Deflector Assy -lists for $36.34
Old 10-02-2005, 06:13 PM
  #97
Onyx 02's Avatar
Default Parts list for 99-02 Silverado
12499467 RPO LQ9 6.0 crate motor
24221888 4L65E trans assy for Z06
12471325 2500 9 1/2" ring gear axle housing
88937339 smooth bumper cap
12335826 painted front bumper
15005294 air deflector for fog lamps
12495928 fog lamp kit (harness, lamps, switch)
15182288 grey W/T grille
12335633 "bowtie" emblem
16526133 headlamp assy
16526134 headlamp assy
15199559 corner lamp assy
15199558 corner lamp assy
15745931 HD hood panel
15058093 HD hood insulator
15171404 radiator upper deflector
15179498 upper radiator hose
12576450 serpentine belt for 105 amp alt.
12576451 serpentine belt for 130 amp alt.
12479757 left front fender
12476220 right front fender
88963556 front L/R brake rotor
15112380 front L/R wheel hub assy
18041762 front brake pads
26100839 turn signal switch w/ cruise control
24229658 M30 (4L60E) deep trans pan assy
8654799 M30 (4L60E) trans pan gasket
29536526 4L80E trans pan gasket
25315809 front O2 sensor L/R
25312201 rear O2 sensor L/R
10464453 130 amp alt. new design
10392759 145 amp alt.
10246636 battery insulator
15321247 positive battery cable
15321221 negative battery cable w/ 12 volt supply
10457730 Delphi brand ignition coil L/R
89017477 ignition coil harness L/R
10465561 starter
15036135 LS cab emblem L/R
15036136 LT cab emblem L/R
15769398 small overhead console
15769400 large overhead console
88938361 split bench seat cup holder
15753266 dash pull-down cup holder for split bench
88937153 right front seat belt assy
88935285 left front seat belt assy
15179830 heated outside mirror
15179829 heated outside mirror
15198010 '03 outside signal mirror
15198009 '03 outside signal mirror
15017224 front door shell assy
15017223 front door shell assy
15054679 front Bose speaker L/R
15099926 front door moisture shield
21996547 front door moisture shield
15766962 lower front door moisture shield L/R
15095844 power window regulator
15101785 power window regulator
12476244 ext cab door shell assy - Left
15017365 ext cab door shell assy - Right
15045510 ext cab door moisture shield - Right
15047591 ext cab door moisture shield - Left
15101396 ext cab door Bose speaker
15054681 crew cab rear door Bose speaker
15054680 crew cab rear door Bose speaker
15162635 crew cab rear door moisture shield
15162636 crew cab rear door moisture shield
12498122 sliding rear window
15758519 Left stepside bed panel
15758520 Right stepside bed panel
15063570 stepside tailgate
15120160 Left fleetside bed panel
15120163 Right fleetside bed panel
15131974 fleetside tailgate
15197873 SS tailgate cap
15707442 Z71 bed decal
15070426 Denali emblem
15178666 SS emblem
15222752 VHO emblem
15712800 rear brake rotor L/R
18048083 rear brake pads
12479031 outer wheel bearing L/R
9436881 inner wheel bearing L/R
12471686 axle housing seal L/R
12474019 leaf spring hanger
12474018 leaf spring hanger
15124395 spring shackle L/R
25345026 fuel pump assy
89060640 fuel level sensor
15734493 seal for fuel pump
15198453 '02 taillamp assy
15198460 '02 taillamp assy
15198462 '03 taillamp assy
15198463 '03 taillamp assy
16525098 taillamp retainers 2/pk
5978459 3rd brake light lense
12496085 fleetside rear bumper kit (chrome)
12496087 stepside rear bumper kit (chrome)
88944059 fleetside bumper bar (paint to match)
15738017 fleetside top bumper pad
15738018 fleetside top bumper pad
15738019 stepside top bumper pad
15738020 stepside top bumper pad
12335696 center step bumper pad
12335660 SS rear bumper cover assy (use factory rear bumper bar)
12335692 SS top step bumper pad
12335694 SS center step bumper pad
Old 10-15-2005, 11:18 AM
  #98
Default Vortec Max Engine Cover
Does any one know the part# for the new VORTEC MAX Engine Cover
Old 10-15-2005, 10:46 PM
  #99
Destroyer of Transmissions
1SlowHoe's Avatar
Default Helpful Link
https://www.rockauto.com/applet3.html
Will give you part numbers after you enter truck year and make etc...
Old 11-13-2005, 08:56 PM
  #100
Onyx 02's Avatar
'03 Silverado tail light harnesses:
16531401
16531402
per Creederado
Quick Reply: 05 6.0L MAF connector part #
