05 6.0L MAF connector part #
#73
Crank Pulley bolt 11516618
Paintable fender flares kit 03 Sierra Front= 12498564 ( $150)
Rear= 12498565 (Fleet)
15073350 - 2002 Escalade Dash Cluster
15150964 - 2001 Denali Dash Bezel
15048578 - Manual Door Lock Switch Lever
15042047 - Dash Trim and Panel Clips
26066456 - Rear Diff Gasket (10 Bolt)
25014748 - Oil Filter
25313349 - HD Air Filter
52485513 - Standard Cabin Air Filter
12489479 - Charcoal Cabin Air Fliter
25055052 - Fuel Filter
Instrument Panel Bezels
15046576 - Graphite
15772854 - Ebony
15772855 - Med Neut
15075113 - Denali (Black Cherry Woodgrain - 2 switch pods)
15075114 - C3 (Black Cherry Woodgrain - 4 switch pods)
Denali Door Switch Panels
15151865 - LH (Black Cherry Woodgrain)
15151866 - RH (Black Cherry Woodgrain)
15149708 - Plastic Retainers for Wheel Flare
25179136 - PCV Valve (original type)
12572717 - PCV Valve (fixed orifice type)
12192195 - Spark Plug Cable (110 mm)
Denali Inside Door Handles
15029903 - LH Front & Rear
15029904 - RH Front & Rear
Escalade/Denali Engine Cover
Fits 2001 & later engines only
12568627 - Escalade Center
15006419 - Denali Center
15006418 - Right
15006417 - Left
15062684 - Escalade Head Light Control
Escalade AC *****
09379893 - Main AC Control
09379907 - Rear AC Control
GMC Denali Projector Head Lights
15166756 - LH
15166757 - RH
15075121/22 00 SILVERADO FENDER LINERS
10121502 - FENDER RETAINER CLIPS
15006532 - DOOR PANEL FASTENER
15048578 - MANUAL LOCK/UNLOCK
15039359 - MEDIUM GREY DOOR PANEL
15046609 - 99+ TAILGATE COVER
15735965 - RADIATOR/ENGINE BAY COVER
26066456 - Rear Differential Gasket
15032997 - Auto-Trak II Transfer Case Drain/Fill plugs
15704050 - Transfer Case/Transmission gasket
2378508 - Auto-Trak II Transfer Case Fluid (The "Blue" stuff)
15757714 - Fleetside Air Deflectors (pair of black deflectors on the 2001 fleetside pickups
between the cab and bed)
12561486 - Stock 5.3l Engine Cover (1999-2000)
12477702 - Yoke Assembly - Nickel Plated - 1500 Series
12477704 - Yoke Assembly - Nickel Plated - 2500 Series
88959384 - LS1 Installation Guide
25534322 - LS1 crate engine
CAM
CYLINDER HEADS
12562319 - 5.3L Truck Cylinder Head
12561875 - 99-00 6.0L Truck Cylinder Head
12562319 - 01-02 6.0L Truck Cylinder Head
12558807 - 98 LS1 (F & Y-body) Cylinder Head
12559855 - 99-01 LS1 (F & Y-body) Cylinder Head
12560801 - 2001 LS6 (ZO6) Cylinder Head (Bare)
12564825 - 2002 LS6 (ZO6) Cylinder Head (Bare)
12560696 - Valve cover gasket
DRIVETRAIN
8642079 - Corvette Servo Piston
8673039 - Corvette Servo Housing
17113555 - 5.3 truck Fuel Pressure Regulator
12557840 - Crank Pulley Bolt
12563964 - LS6 Oil Pump
12568002 - 2001 LS6 Engine Valley Cover
25312197 - Left Front O2 Sensor
25312196 - Right Front O2 Sensor
25312196 - RH O2 sensor
25312197 - LH O2 Sensor
25509274 - O2 Delete Plug
15046576 - Graphite
15772854 - Ebony
15772855 - Med Neut
15006418 - Right
15006417 - Left
Escalade AC *****
15166756 - LH
15166757 - RH
CAM
CYLINDER HEADS
DRIVETRAIN
#75
Originally Posted by 04BlackGmc
Btw i cant find but P/N please for the front and back Fender flares!
thanks!
03-04 sierra
thanks!
03-04 sierra
its there,
2003 + UP GMC ITEMS
2003 gmc base model sierra grille = 15773418 ($150-200)
Onyx Black Smooth Tailgate handle(off SS)= 15188001 ($33.64)
Bezel = 15187998 ($19.98)
