05 efan pigtails
Old 06-28-2009, 07:29 PM
11 Second Truck Club
bluecajun5.3's Avatar
Default 05 efan pigtails
i am in need of them.
could yall point me in the right direction on where to get some?
thanks,
Lance
Old 06-28-2009, 07:39 PM
1Bear's Avatar
You may not be wanting to get them from the dealer and as I recall they were fairly expensive for what they are, but never the less the part numbers I have for the connectors to the motors are: 88987983
Old 06-28-2009, 07:42 PM
KySilverado's Avatar
These will work.
http://cgi.ebay.com/ebaymotors/85-02...Q5fAccessories
Old 06-28-2009, 07:56 PM
thank you!
Originally Posted by KySilverado
i already have a black bear harness but it is setup for the ls1/lt1 style fans. it's the same connector you just posted. i thought they different from the truck efan connectors?
Old 06-28-2009, 08:00 PM
FormerVendor
Derek @ EDO's Avatar
Originally Posted by bluecajun5.3
thank you!
They are different but will work.
Old 06-28-2009, 08:03 PM
thanks Derek! work with a lil modification i'm guessing?
i don't have the fans yet, that is why i'm asking so i can get it done all at once and not waiting/hunting down parts...
Old 06-28-2009, 08:04 PM
FormerVendor
They actually plug right in, ill snap a pic for you where you can have a better understanding.
Old 06-28-2009, 08:21 PM
Yeah they will plug in and work, seal up. I had to just trim the snap/lock a bit to get it to fit just so.
Old 06-28-2009, 08:23 PM
FormerVendor
As you can see, the LS1 plug retaining clips are slightly wider than the 05+ fan plug in.
If you cut off, with a razor blade knife the plastic encircled on the LS1 clips it will be perfectly functional with the 05 fans, if you do not trim the connector it will not seat within the groves and can potentially vibrate off.
Derek
Old 06-28-2009, 08:31 PM
man yall are the best!
thanks for the quick response and for the explaining Derek and Roger!
Quick Reply: 05 efan pigtails
