10 bolt brake help
10 bolt brake help
its come time to rebuild my 10 bolt rearend
the brakes are it bad condition esp. the drum in hat (emergency brake) setup
i was wonderin if anybody knows of a disc brake setup that bolts up to the exsisting holes
thanks
thanks
Custm2500's Rude Friend
I Helped some one do the swap on an 06 crew cab V-max and the rears were nearly locking up under hard brakeing condition. A Gm Dealer Won't flash the ABS unit because of Liabilty. After talking with some people in the Brake industry the solution was to install an after market porportioning valve that can be manualy adjusted.
Glad to See your swap went well. Its worth it In my opinon Too! I have an 00 Wich was 4 wheel disc from the factory. I am going to upgrade to 05- up Larger fronts, add hydro boost and run the twin piston calipers off an SUV in the rear.
There is no individule Valve. Pressure is controlled at the ABS pump manifold.
i am running the hydroboost with 05 fronts and suv rears...stops great and a vastly improved pedal feel. best bang for the buck by far.
mrgrim
07-08-2015 08:12 AM
