1000rwhp?
Originally Posted by parish8
that is siting on the same header is i have now. it is going to sit higher since the turbine is much larger.
4.8t, your right, the turbine is huge and the compresor housing isn't that much bigger. it is rated at 1250hp. the inlet is 4" and outlet is 3", the outlet on the turbine is 3.75"(odd huh).
Originally Posted by redaddiction
Good luck with your goal but do you ever plan to make your truck certified to run 9's without getting kicked out ?
13 Second Truck Club
tires
yeah you definetly need some slicks or at least some z rated tires if you put any more power to the wheels the tires will probably spin of the rim it would be an interesting feeling to see your tire pass your truck while your goin down the track it would probably run like a 9.5
LS1Tech Sponsor
Gonna have to put some tires on that thing. You are gonna try to make it hard on me this Summer. Oh, well I still think you should head up this way at the end of July. It would be some good fun.
