145 alternator
PT's Slowest Truck
I *think* that the abs system monitors battery voltage to be sure that there is enough reserve juice to fire up the abs solenoids if necessary. Pretty sure that there are ABS codes for low battery voltage...If your truck is not equipped with that wire, I bet you could run the alternator and it wouldn't affect it's operation. You might just have to get the square connector and wire it in
PT's Slowest Truck
I don't see why not, I have an 02 PCM and I'm running a 145 amp alt from an 03...I just had to run 1 wire from the alt to the PCM that my 99 harness didn't have. Since you're an 02, that wire should already be there (I believe it was the duty cycle wire that I had to run)
