145 alternator
PT's Slowest Truck
I had to run the wire after installing the 02 PCM, as I was getting a slow blinking battery light. The addition of the wire and alternator cured that issue. Creederado and 99Silver5.3 had to do the same thing at the time also. I think that the tuners (Nelson, Wheatley, BlackBear) figured out a way around that eventually. Are you running a 99 PCM?
*EDIT* Now it's all coming back to me...been a while lol
EDIT-I do however have EFI Live and I can't remember if I deleted any codes or not. The may have been it.
PT's Slowest Truck
That may have been the case...IIRC, I swapped the pcm first and got the light. Then I ran the wire to my 105amp alt but the light stayed on, finally I swapped in the 145amp alt and the light went away. Creederado was the first one to figure this all out I think, but I think that he did the wire and alternator at the same time. I know for sure that guys have figured out ways around having to use the alternator and wire since I originally did mine. It's been working for me for about 4 or 5 years now so I just left it that way.
PT's Slowest Truck
I'll bet that it's a battery voltage signal to the ABS system (just a guess)...I was just looking at the schematics, and realized that you have the 04 that utilizes that wire. Do you have that wire somehow hooked in to the new alternator? You could try installing the old alternator and monitoring that wire with a voltmeter to see what kind of voltage is there and possibly tap that wire into one of the other wires off the the alt (if it's deleted from the new plug)
lxcoupe
10-26-2015 10:13 AM
drummer0415
11
10-24-2015 08:16 PM
SlvrSierra4.8
10-01-2015 09:39 PM
