1977 K10 Info
1977 K10 Info
My brother has a 1977 Silverado K10 350ci granny 4sp manual. Possible swaping to a TH350 in the future though.
What axles does it have? Dana 44's front and back?
He wants 4.10s and some type of Positive traction in the front and rear... i suggested a Truetrac in the rear.. not sure in the front.
Do any of you guys have any info on these trucks?
I have a 1984 K-10 with 10 bolt axles and I have a Detroit c-locker in the rear and I love it. I have a powertrax locker in the front and I would not recomend putting a locker that can't be disabled in the front. If I wasn't trying to sell the truck I would take the front locker out. It just make it harder to turn the truck in 4wd not nearly as fun to drive and not really much off road gain from adding it over having the locker in the rear and an open diff in the front. It does make it easier to break front axle U-joints tho.
Import Moderator
Thanks man!!!!
Now for the front diff..
Are there different gears or do they use the same as the rear?? ive never dealt with a 4wd so help if you can.
chances are its a dana 44 up front and 12 bolt out back, most of them trucks were heavy halfs, the frames are thicker than 80-87 ones
Originally Posted by 1969x11
I was told you could run the truck off-road if the ratios were close, say 3.42 front and 3.73 rear.But you couldnt engage the 4wd on a hard surface. what do you guys think??
KINGCYCLES
10-02-2015 10:21 AM
