2 tire size
12 Second Club
I would go with the same or closer diameter front and rear. Typically you would put wider tires on the rear.
On my Impala, back when the ABS actually worked and it had 3.73 gears, I put 2" shorter tires up front and the ABS light was triggered. There was too much of a difference in wheel speed between the front and rear. However, when I put the shorter tires on the back, I had no problems.
one more question, I will have to travel about 60 miles to my tuner for him to set up the 275/45/20 from the 275/55/20, do you see any problems doing this
thanks
-tommy
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
luisalmighty09
08-20-2015 11:35 PM
