2000 Powerseat swap
2000 Powerseat swap
Hey guys I'm installing sum powerseats from an 05 into a 2000 LS Silvy that has manual seats,Just wanta know what to expect as far as powering them up,Or will it be a nightmare?...................Thanks in advance
Ive looked into this. My conclusion was this. The plugs are not compatible between the 99-02 and 03-07 seats. Cut the connector off the harness from your seats as well as the connector from the new seats. Then simply connect the power and ground wires. As far as if the seats are heated are not, you'd have to also wire the switch for that somehow.
I did this with my 2000...I just did like GMCtrk said with power, fuse and ground...I havnt spent the time looking for a wiring schematic to wire the heated seats but maybe someday
Heres my thread I made about the swap...
https://www.performancetrucks.net/fo...hlight=ss+seat
Shtbox
08-02-2015 10:52 PM
