28" radiator to 34" swap question
Old 03-16-2011, 01:17 PM
Jokeman's Avatar
Default 28" radiator to 34" swap question
Ive searched around regarding this swap. I am planning on a 34" aluminum radiator once the weather gets a little nicer. Do the original hoses for the 28" fit or will I need to buy longer hoses?
Thanks
Old 03-16-2011, 01:28 PM
How do I change this text
Wilde Racing's Avatar
I can't remember replacing them on the trucks I converted.
Old 03-16-2011, 01:43 PM
Three6GMC's Avatar
I have done this swap a couple times now everything works fine just swap the radiators and put the bigger fans on and it will work. I have some pics when I did the swap to my 01 I'll post them later today... Right now it's beach time!!! Lol
Old 03-16-2011, 01:48 PM
I have a gauge for that
Atomic's Avatar
Yep, everything works fine
Old 03-16-2011, 01:54 PM
Jokeman's Avatar
Cool thanks for the heads up. Appreciate it.
Old 03-16-2011, 02:55 PM
PT's Slowest Truck
budhayes3's Avatar
Re-use the same hoses, but you'll have to cut the rubber flaps on the sides of the tanks of the 28" radiator, piece of cake. You'll see what I'm talking about when you pull the old rad out
Old 06-10-2011, 05:35 PM
Slow91z's Avatar
?? Curious what you mean here...thinking about doing this swap, but only want to do it if it's a straight bolt in.
Old 06-12-2011, 07:15 PM
oldred95's Avatar
Everything is the same. If you look at it now with the 28 inch radiator you can see how the hoses are kind of kinked over towards the drivers side so they hook up to that narrow radiator. With the 38 inch radiator it all looks better like it was meant to be that way.
I didn't have to mess with the rubber flaps. They were already wide enough to fit the wider radiator.
Old 06-12-2011, 09:32 PM
Coban's Avatar
He means exactly what he said. It is a straight bolt it.
Old 06-13-2011, 03:43 PM
Bryant01's Avatar
I did this swap this weekend. EASY SIMPLE and great upgrade.
Quick Reply: 28" radiator to 34" swap question
