350 TBI heads
Old 03-16-2010, 08:10 AM
Registered User
davbell22602's Avatar
Default 350 TBI heads
Does anybody what direction I need to take in finding heads that will work with a 700CFM throttle body and bored 2in refurbished intake? Do need to have the stock heads fixed at a machine shop to flow with the 700cfm?
Old 03-16-2010, 06:33 PM
dirt track racer 81's Avatar
Ditch the tbi heads. they are junk, even ported they wont even turn 4500 rpm..
Old 03-17-2010, 03:53 AM
Manbearpig's Avatar
Theyll turn 4500 just not over 5500
Old 03-17-2010, 07:18 AM
9 Second Truck Club
stock48's Avatar
Look for a set of heads off of a 87~92 Z28, or 87~88 Carbureted Caprice 350. They don't have the cork screw, and will bolt up to your intake.
Old 03-17-2010, 01:22 PM
Registered User
ok, thanks for all the responses and any future responses.
Old 03-18-2010, 12:43 AM
Manbearpig's Avatar
Haha I have some 193 FAILports off a 93 TBI truck on my K5
I want to rip them off, burn them and **** on them
Old 03-18-2010, 08:25 AM
Registered User
What?
Old 03-18-2010, 06:42 PM
theyll turn whatever just wont make power beyond 4500..
Old 03-24-2010, 10:10 PM
oldred95's Avatar
From a performance stand point they are best served as a wheel chock or a door stop depending on the size of your door. They did the job they were intended to do very well though. Fairly efficient design with good lowend power but for some reason those heads always spark knocked like no other. It was like having a couple of ball peen hammers running around loose under the hood.
The L98 heads are a decent option that will bolt up to the stock intake. Vortec heads are a lot better option but then you get into the whole what intake to run problem. AFRs or some other aftermarket heads are great but then you get into the whole how am I going to afford this problem and once that is sorted out the how am I going to tune this thing so it will even start and idle problem.
Old 03-25-2010, 10:48 AM
Registered User
Summit recommended these http://www.summitracing.com/parts/WRL-043650-1/
Quick Reply: 350 TBI heads
