3rd brake light
3rd brake light
My 3rd brake light won't work... Checked every fuse and none blown.. Changed a few just to double check.. My rear brake lights work so i know it's not module.. Any suggestions??
PT's Slowest Truck
If the fuses are all good, and the factory unit doesn't work, you probably have an open circuit somewhere. Check for power and ground and see what's missing...do you have a digital multi-meter? You can use a test light in this instance though, since it's a simple lamp circuit.
