4 Piston Brakes: 2020 Silverado 1500
Old 08-14-2022, 06:36 AM
adriver's Avatar
Originally Posted by Fullpower
My measurements and posted picture indicate that the 13.5" rotor is about an 1/8" taller ( ie more BACK SPACE) as compared to the older NNBS 12.99" rotor. Using the correct, appropriate 2020 spec 13.5 inch rotor should NOT require additional, non factory SHIM or spacer to center the 2020 spec 4 Piston caliper.
..... I "think": that those shimming/spacing the caliper are trying to compensate dimensions to continue running the old, smaller rotor with the NEW 4 piston calier, which I wish to avoid.
.... " We don't want no STEENKING Shims"
I will update this thread when I get everything lashed up.
No, I'm saying with the new larger rotors. The rotor hat size is different. The only way the new calipers will sit centered over the rotor, is if the caliper's center to knuckle mount, only changes by the difference in the hat size. The calipers themselves are larger, and (based on the video, and what others have said about this) there must be a different mounting position on the 2019 knuckles.
Here's 7:38 video on the entire swap, showing the shim. When you add the shim to center the caliper, you push it that much farther out.
Fullpower (06-28-2024)
Old 08-23-2022, 11:42 AM
dantheman1540's Avatar
Originally Posted by shakenfake
It's not it is just a cast mark. You can grind it down with no adverse effects. I don't see why that would help caliper strength unless you are saying that they crack down the middle. In which case I'd like to see a documented failure of that. @dantheman1540 has ground them down and has been on them for a while
17s won't fit though, need 20s or bigger.
17”s will fit but it depends on the wheel.
I have 30k miles with lots of towing, and aggressive driving on my ground down calipers. No issues to report except all other vehicles I drive feel to have inferior brakes.
Old 08-23-2022, 07:55 PM
adriver's Avatar
17" FACTORY wheels?
Old 08-23-2022, 08:08 PM
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
@adriver Correct, T1XXs came with factory 17s and 18s lest we forget.
Now generations before then I am unsure.
I said 17s won’t fit because I was thinking about 6 piston, pretty sure those are too big.
Old 08-23-2022, 08:09 PM
adriver's Avatar
ahhh okay. I might be getting those mixed up at some point.
Old 08-24-2022, 06:06 AM
Iirc OEM NBS Denali 17”s did not fit with the 4 pistons. A set of 17” method roost wheels I had fit as well as PPV steelies which was surprising.
Of course that was with the hump ground and possibly a 1/4” spacer I can’t remember but I know that I posted it somewhere.
Old 06-24-2023, 06:26 PM
supermaro's Avatar
Delete …
Old 04-09-2024, 12:00 AM
Fullpower's Avatar
Update:
Still very happpy with 13.5" rotors, HydroBoost and four piston 2020 spec Half-Ton brakes, retrofitted to 2002 Tahoe. Best brakes I've EVER used on any pickup truck..
DATA Point: factory GM 18" Aluminum wheels from 2017 will NOT clear the four piston brakes.
strutaeng (04-09-2024)
Old 06-28-2024, 01:32 AM
Fullpower's Avatar
Originally Posted by wardlws
I've seen the bump ground down flat, but you risk catastrophic failure. .
Also, be prepared for the brake pedal to travel further for the same amount of brake force, since these calipers require more fluid.
Thank you for the warning about getting out the GRINDER.
I am still Running the calipers whole, " As Cast "
Brake pedal TRAVEL was not increased by any perceptible degree.
The 2020 front brake parts fit well, and work well.
VERY good, easily modulated brakes. Still easy to use on ice, and snow.
JNewby96 (07-03-2024)
Old 08-22-2024, 01:01 PM
Registered User
CRASHIDAHO's Avatar
so i just got - im a delaer tech and just recived the 2024 yukon at4- 4 piston calipser-rotors-back plate- i am gonna try to fit my 2010 1500 serria- will update with pics tomorrow
wretched73 (08-22-2024)
Quick Reply: 4 Piston Brakes: 2020 Silverado 1500
