4x4 to 4x2 conversion - Tranfert Case Delete, no more speedo
Old 12-02-2010 | 03:31 AM
matthew20061's Avatar
Originally Posted by AKlowriderZ71
WTF?? Pics please. What are you doing for your rear driveline?
So did he just like gut the transfer case and still use the rear output shaft of the transfer case? I'm confused to how that even works....
Old 12-02-2010 | 03:36 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
He had pics of the t-case and other removed parts out of the truck.
Originally Posted by Brice
I've got the 4wd service light on and no speedo (stuck in first gear)
I have removed the différential case and keep the output saft and tail housing.
I've got 2 Vss on the transfert case, I've unplug the front one and keep the rear Vss.
About the front hubs, I've kept the stock one and I've modified them.(The front ABS sensor stay stock).
How can I disable the 4WD fonction ? Do I really need a need tail housing for a new VSS provision?
Is there a specific PCM wiring for 2WD (and work with my rear Vss on my empty tranfert case?
Removal of the front differential case.
Hubs modifications:
See??
Old 12-02-2010 | 05:09 AM
Brice's Avatar
exactly, I've gut the TC and use the rear output shaft.
it works! I will take pix this afternoon. I'm running it and tuning it using Hptuners control for shifting.
I've got ABS light and 0 speedo (so no shifting), I can shift manually to 1 and 2 gear. (No DTC)
I'm living in France, output shaft shipping is expensive (long part). That's why I've choose this solution.
Old 12-02-2010 | 06:44 AM
Brice's Avatar
here are the pix :
Removed parts in the transfert case :
Some pix :
I've just found that the VSS is the blue plug.
Old 12-02-2010 | 06:50 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
you need the rear most vss for your computer to read the speed in which it is turning, and if it cant read that it wont shift either, make sure you have the right vss plugged in
Old 12-16-2010 | 02:48 AM
LSfan70s's Avatar
Thumbs up
I also need to do 2WD my TC, but I have a a NVG149, what parts exactly do I have to remove from the TC to make it 2WD?
You can indicate the parts with the numbers bellow.
Thanks in advance.
gaps
10-15-2015 03:53 PM
chvy=power
09-08-2015 12:06 PM
screaminian47
09-07-2015 09:20 PM
iregret
09-07-2015 02:20 PM
Alvin@PCMofNC
09-03-2015 07:38 AM
