5.7 For 5.3
Truck addict
are you asking can you install a ls1 5.7 to replace the 5.3? if so the answer is yes. I dont' think there is that much trouble in doing the swap. however, there are some guys on here that have done it.
Originally Posted by redwagon63
Can A 5.7 Ls1 Be Swapped For A 5.3 With Little Trouble?
Originally Posted by TnTrk53
Yes. most guy's stay with the ls1 intake and modify the larger Ls1 fuel rails to fit. Saw that trick on amy's 12.1 sec rcsb . More power less weight how can that not be good.
I'm looking at maybe picking up an LS1 here pretty soon and had a question;
Should I, swap the 5.3 intake and heads onto the 5.7 block or leave the whole 5.7 setup the way it came from the factory? Just wondering what would make better power.
Also if I leave the 5.7 the way it is, I can still use my 02' 5.3 PCM with it just have it recustom tuned correct?
Thanks
Thanks
Thanks
Thanks
The stock PCM will drive the 5.7L engine just fine for starters. I would eventually get a retune to realize the full power potential tho.
Again, overall an easy swap.
