6.0 iron block or LS1 ??
Old 10-18-2006 | 09:07 PM
gtosilverado's Avatar
Default 6.0 iron block or LS1 ??
which motor is better ?? with stock 5.3 heads....
Old 10-19-2006 | 12:27 AM
goshawk23's Avatar
Truck addict
weigh the pro's and cons. the 5.7 is lighter. the 6.0 has more displacement. if i had both available i'd probably go 5.7. if i were boring and stroking then the 6.0. btw i have 5.3 heads on a 6.0 and love it
Old 10-19-2006 | 01:29 AM
TXsilverado's Avatar
cant go wrong with either setup IMO. if you plan on bumping the cubes go for the 6.0 IMO
Old 10-19-2006 | 02:05 AM
no, not really looking to change out the crank, pistons, rods, heads....
Old 10-19-2006 | 09:30 PM
Mangled03gmc's Avatar
Baltimore Whore
I would go wit the 6.0 it has more cubes although the ls1 is lighter, but the 6 would be the way to go, also you can usually find 6.0's cheaper then ls1's
Old 10-20-2006 | 03:46 PM
ls1 longblock for 450 here
Old 10-20-2006 | 03:58 PM
vanillagorilla's Avatar
Where? Was it running or just a core?
Old 10-20-2006 | 03:59 PM
Scream's Avatar
MOOBIES Moderator
I like the LS1. Better gas mileage and great power w/ even a small cam. I'm biased though.
Old 10-20-2006 | 04:01 PM
from a buddy of mine. its running. still being driven daily in his camaro. im getting it with some lq9 injectors/oilpan all plugs, wires, throttlebody, heads EVERYTHING!!! i just got lucky lol.
Old 10-20-2006 | 04:50 PM
Last Call's Avatar
TOTM: January 2007
Love your sig bro. Good luck with that!
